Garmin Edge 1030
Miciomacho
27 Dicembre 2016
208
200
52
Prato
Giant TCR Advanced Pro 0 + Wilier Triestina JENA Ekar
Firmware 7.85 beta
Changes made from version 7.50 to 7.85:
  • Training Load Focus. Low Aerobic, High Aerobic, and Anaerobic stats are tracked over a 4 week window and the user should be able to track what needs to be focused on.
  • Two-way setting sync. Changes to some settings made on the Edge (zones, user profile, etc) will now be uploaded to Garmin Connect.
  • Heat/Altitude Acclimation. Shows user's acclimation to different altitudes and hot/humid environments.
  • ClimbPro. See upcoming climbs while riding a course so you can prepare for needed effort
  • Power Curve tracking has been added to the My Stats menu.
  • Nutrition/Hydration tracking alerts
  • Training Plan Review Page Improvements
  • Workout Comparison Graph. Provides live feedback while executing a workout.
  • Widget Management. Disable and re-order items in the widget loop
  • Bike Theft Alarm*. While armed, get alerted when your Edge device moves.
  • Find My Edge*. Help find a misplaced Edge by making it beep or showing its last known location on your phone.
  • Grit/Flow**
  • Jump Metrics**
  • Added a new Popular data field category and generally improved the data field category order
  • Updated screen creation and editing flow (applies to eBike/STEPS, Lap Summary, Segment, and Data Screen)
  • Ability to swap data fields while in the timer loop on long press instead of edit only (additional tap required)
  • Updated battery icon to be more visible in some places
  • Incident detection setting is now active per profile instead of globally
  • Added ability to hide data screens without deleting them
  • Reordered settings to match the Edge 830, mainly splitting the growing number of settings into Safety & Tracking (Incident Detection, Get Assistance, Contacts, GroupTrack, Bike Alarm) and Connected Features (Phone, WiFi, Device Transfers)
  • Additional small changes and improvements
* Complete functionality requires an upcoming Garmin Connect Mobile release
** MTB Profile
Installata stamani, a parte il primo riavvio particolarmente lento, una volta sincronizzato con l'app nessun problema. Oggi pomeriggio la provo
Inviato dal mio SM-G973F utilizzando Tapatalk
baffobaffone
18 Giugno 2013
1.516
141
Thiene (VI)
www.strava.com
Ciao a tutti... dopo 4 mesi di inutilizzo del 1030 ho visto che il sensore di velocità non dava piu segni di vita.
A quel punto ho sostituito la batteria,ma niente ,non si accende e il dispositivo non lo riconosce.Ho provato a lasciarlo una notte senza batteria ma e stato inutile.Ho notato che la batteria originale era un cr2032 H mentre quella che ho messo io è sempre (ovviamente) un cr2032 ma non ha l'H...
Altra cosa,come mai dopo l'ultimo aggiornamento,quando si attiva il rilevamento incidente mi suona il telefono ma non mi appare sul 1030 la possibilità di disattivare l'allarme ? saluti alessio
Garmin consiglia di mettere la batteria all'incontrario per almeno 30 secondi se non sbaglio, vedi se si riprende.
graziano.moscacp
29 Gennaio 2015
6
De Rosa King RS
Provato questa mattina il nuovo firmware 7.85 con BDC. Tutto ok. Per adesso pur essendo una versione beta è molto stabile. Mi sembra di aver notato anche una maggiore reattività del 1030. Devo provare le nuove funzionalità con la MTB.
Reactions: Miciomacho
Miciomacho
27 Dicembre 2016
208
200
52
Prato
Aggiornamento dopo prova nuovo firmware beta:
Inserito ed eseguito allenamento da trainingpeaks senza problemi.
Caricata l'attività su GC senza battere ciglio.
Domani faccio un lungo in montagna e provo la funzione climb pro.
Anche a me impiega qualche secondo in più in fase di accensione ma poi mi sembra addirittura più fluido.
Rapasave
2 Giugno 2009
12.752
695
Alto Adige - Süd Tirol
Di quanti Mah è la batteria del 1030? Dovrei fare un giro di circa 24 ore con navigazione (no telefono connesso) ma tutti i sensori collegati...pedali assioma di2 e garmin varia...con un powerbank da 5000 dovrei farcela....
Inviato dal mio S10 Ipbike powered
albifly
20 Marzo 2012
91
supersix
Ciao a tutti. Oggi bellissima uscita ma è sorto un problema: alla mia ragazza segna 220km a me 205... È la prima volta che sballa di così tanto, di solito la differenza è di qualche centinaio di metri. Anche il dislivello diverso... Cosa può essere? Il sensore di velocità ha la batteria nuova e sembra essere associato ma non garantisco... In galleria ad un certo punto mi ha segnato 0kmh, dal menu sensori ho connesso quello della velocità e funziona... Grazie!!
carbal54
3 Novembre 2009
8.305
1.296
Sanremo
alcune :-)
Dove vedi la differenza? Su Garmin Connect? Su Strava? Su XXXXX? Garmin Connect (almeno per quanto ne so io) è l'unico che mostra la distanza registrata dal sensore (se presente) mentre gli altri rifanno il calcolo usando i punti GPS. Se per esempio Strava ti mostra 10 e GC 9 ecco che il colpevole è il sensore che, a volte, può funzionare un po' sì e un po' no, perdendosi dei chilometri per strada. UN modo veloce di controllare è scaricare da GC il file in .tcx, salvarlo sul desktop e poi drag-and-drop su http://www.mygpsfiles.com/app/ vedi subito se la distanza segnata è diversa.
carlo
giulio.gennari
1 Gennaio 2011
5.291
2.798
42
apennino parmense
Tarmac SL7, Specialissima Pantani, Lee Cougan Cross Fire
Personalmente con Vector attaccati, Varia, fascia cardio e Navigazione mi è capitato quasi sempre che verso fine giro il Garmin si inchiodasse.
La batteria sono praticamente certo che ne avrai a sufficienza
dexter.ale
18 Luglio 2010
301
8
42
Trek emonda SL8....Santacruz nomad carbon
Da quando ho fatto l'ultimo aggiornamento al 1030,sono di nuovo alle stesse magagne che avevo ad aprile. Il rilevamento incidente mi fa vedere la notifica che è partito l'allarme ma non si è visualizzato sul 1030. Non arrivano le notifiche di wzapp e non riesco a cancellare le corse che ho fatto passate. ;nonzo% ho provato a fare anche un hard reset ma niente. Avete delle soluzioni? whisp
albifly
20 Marzo 2012
91
supersix
carlo
Abbiamo lo stesso strumento, stessi sensori e abbiamo fatto lo stesso giro. La distanza corretta non è la mia, vorrei capire perché il mio sensore di velocità si disconnette e parte il rilevamento dal GPS che in zone con difficoltà di segnale prende con poca precisione
Rapasave
2 Giugno 2009
12.752
695
Ma non è ancora in fase beta?
carbal54
3 Novembre 2009
8.305
1.296
Sanremo
alcune :-)
La ragione più probabile è che la batteria del tuo sensore sia scesa sotto i 2.8V. A quel punto il sensore inizia ad andare "a singhiozzo".
carlo
Rapasave
2 Giugno 2009
12.752
695
Ho provato il garmin 1030 ieri pet la prika volta in modalità navigazione.
Ho fatto un giro da 430km..conoscevo un pò il percorso l'avevo fatto 7 anni prima.
Premesso che gli ho dato un file gpx preso dal giro di strava.
Ecco i miei commenti..
1) spesso perdeva la traccia...messaggio fuori rotta vuoi fare il ricalcolo ? Dopo qualche secondo la trovava da solo
2) molte volte mi mandava su strade alternative anche se ero sulla traccia principale...anche questo molto noiso....
3)i segmenti non funzionano in modalità navigazione?
Sbaglio qualcosa nelle impostazioni?...se avessi seguito il navigatore avrei fatto 200lm in più [emoji12]
carbal54
3 Novembre 2009
8.305
1.296
Sanremo
alcune :-)
In linea di principio non sbagli nulla, in pratica... devi adattarti alle stranezze dei Garmin.
Punto 1) non ci puoi fare nulla, succederà sempre, lo strumento confronta la posizione stimata attuale con le coordinate del file che hai caricato, se la differenza è più di X = per lui sei fuori rotta. L'impostazione "tieni su strada" aiuta ma non è risolutiva.
Punto 2) Se la traccia è stata tracciata/registrata usando mappe diverse da quelle presenti sul Garmin, tenta di farti passare per dove vuole lui e non per dove vorresti tu.
Punto 3) Non ne so nulla e non ne voglio sapere nulla. Continuo a ritenere i segmenti una delle peggiori involuzioni del nostro sport.
carlo
Rapasave
2 Giugno 2009
12.752
695
Grazie Carlo...da un punto di vista magari fare strade nuove non deve essere male bisogna fidarsi..
I segmenti li volevo vedere solo per il profilo altimetrico e per la lunghezza della salita ma adesso ci dovrebbe essere la nuova funziona climb pro
Ciao
Save
carbal54
3 Novembre 2009
8.305
1.296
Sanremo
alcune :-)
Ciao
Save
Io adoro fare strade nuove, però, coi Garmin dal vetusto 305 all'attuale 530, la musica non è cambiata. Devo sapere prima di partire dove voglio andare e per dove voglio passare. Prepararmi IO la traccia sul mio software preferito, posso usare un gpx preparato da altri, ma lo metto in background come linea guida. Aggiungo i miei punti corsa per i punti che mi sembrano critici e per gli scollinamenti e fine discese per sapere quanto durerà l'agonia in salita o la libidine in discesa. E controllo che il tracciatore non mi faccia fare "scorciatoie" inutili o assurde, non per colpa sua ma perché le mappe sono tutto tranne che perfette e spesso indicano come percorribili muri impossibili o addirittura scalinate.
carlo
Rapasave
2 Giugno 2009
12.752
695
A parte che solo per dirtene una....file importato in gc...9300mt dsl....reali 5700 [emoji12]
Ho capito che busogna prepararsi bene a prescindere dal navigatore....
Cmq con la modalità navigazione consuma molto di più
Ciao
Save
carbal54
3 Novembre 2009
8.305
1.296
Sanremo
alcune :-)
Climb-pro : bello come idea, ma... dipende TUTTO dai dati del file che hai caricato. Se hai un file con dati DEM il climbpro spara fallomorfi che te lo fanno odiare subito. Se il percorso ha dati da altimetro barometrico è simpatico. Sull'utilità non mi pronuncio, io preferisco usare il vecchio road-book che mi dice quanto manca e eventualmente mettere io dei punti dove so che la pendenza si incarognisce.
carlo
