ciao mi sono appena iscritto al sito , ma come faccio a creare una salita ? premo su " le mie salite" ma non mi fa fare nulla
Per Predazzo, se piove, come ogni anno, faccio il corto e la tiro.
Se non piove, faccio il lungo e possiamo anche farcela insieme, però fai il lungo con me.
Ciao!!
Appena ho 10 minuti ci guardo..
Ciao Gabrielebike,
ho provato ad iscriveri, ma quando cerco di visualizzare il mio profilo utente mi compare questo messaggio:
Server Error in '/' Application.
[FONT=Arial, Helvetica, Geneva, SunSans-Regular, sans-serif]
Come posso risolvere? Grazie
[/FONT]
Ciao Gabrielebike,
Object reference not set to an instance of an object.
[FONT=Arial, Helvetica, Geneva, SunSans-Regular, sans-serif] Description: An unhandled exception occurred during the execution of the current web request. Please review the stack trace for more information about the error and where it originated in the code.
Exception Details: System.NullReferenceException: Object reference not set to an instance of an object.
Source Error:
An unhandled exception was generated during the execution of the current web request. Information regarding the origin and location of the exception can be identified using the exception stack trace below.
Stack Trace:
[NullReferenceException: Object reference not set to an instance of an object.] BikersBook.UserControls.Common.Status.UC_UserStatus_E.SetStatus(Guid userId) in C:\Users\Gabriele\Documents\Visual Studio 2010\Projects\BikersBook_9\BikersBook\UserControls\Common\Status\UC_UserStatus_E.ascx.cs:21 BikersBook.UserControls.Common.Status.UC_UserStatus_E.Page_Load(Object sender, EventArgs e) in C:\Users\Gabriele\Documents\Visual Studio 2010\Projects\BikersBook_9\BikersBook\UserControls\Common\Status\UC_UserStatus_E.ascx.cs:12 System.Web.Util.CalliHelper.EventArgFunctionCaller(IntPtr fp, Object o, Object t, EventArgs e) +14 System.Web.Util.CalliEventHandlerDelegateProxy.Callback(Object sender, EventArgs e) +35 System.Web.UI.Control.OnLoad(EventArgs e) +99 System.Web.UI.Control.LoadRecursive() +50 System.Web.UI.Control.LoadRecursive() +141 System.Web.UI.Control.LoadRecursive() +141 System.Web.UI.Control.LoadRecursive() +141 System.Web.UI.Control.LoadRecursive() +141 System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint) +627
Version Information: Microsoft .NET Framework Version:2.0.50727.4206; ASP.NET Version:2.0.50727.4209
[/FONT]
gabriele, nel tuo sito è possibile modificare nella schermata "uscite" il kilometraggio totale che è impostato a 10000km? grazie
Ciao!
No ma se vuoi lo rendo possibile..
Ragazzi ricominciano gli sviluppi..
Il lavoro comincia a darmi tregua..
Gabriele è possibile creare un link diretto per le squadre?
Mi spiego meglio... implementare nella scheda della squadra (visibile all'amministratore della squadra) la possibilità di assegnare un link diretto, come sottodirectory del dominio bikerslife.net
Esempio: www.bikerslife.net/nomesquadra così uno può mettere il link in firma o nella bacheca della sede della squadra, è più diretto e immediato, e tutti si iscrivono al sito.
Altrimenti bisogna spiegare di andare su www.bikerslife.net, registrarsi, cercare la squadra., etc...
Già dovergli spiegare di installare SilverLight e a cosa serva sarà un dramma! :-)
Ovviamente solo se questo non rischiede un lavoro allucinante!
Cmq intanto provvedo ad inserire il link al tuo splendido sito sul mio blog (sul quale a breve farò anche una recensione) e sul sito della squadra.![]()
Altra cosa che ho notato.
Non si potrebbe aggiungere la possibilità nel "Profilo ciclista" di far visualizzare un nick-name e non il nome e cognome che, a scelta, può essere visibile o meno come pure per la data di nascita? Ossia una casellina da flaggare per rendere visibili o meno alcune info personali.
Forse non ci sono riuscito io ma nel profilo della bicicletta si può aggiungere una seconda o terza bici, che so, per chi come me ha una bdc e una mtb?
