nuova FW 2.6 che elimina la calibrazione dinamica (cruccio per molti)
la seconda cosa che introduce, non l'ho capita
e nuovo vector updater
enjoy!
Beibo
Change Log
Changes made from version 2.40 to 2.60:
Removed dynamic calibration functionality. Testing of previous improvements to the static calibration routine have revealed that this feature is no longer needed.
Improved display channel start times. A timing bug was causing the display channel to only start 30s after wake-up.
New Version of Vector Updater is avaiable for download 3.1.0
The major changes in build 3.1.0 are:
The Vector updater now allows you to perform software updates or make configuration changes to the Vector system without the need to take the batteries out of the pedal pods and put them back in.
There is now an option to adjust the left and right side scale factors should that be required.
For those users with a Vector-S system the updater will let you pair and unpair with a Vector Upgrade pedal (a right side pedal to make it a dual sensing system).
enjoy!
Beibo
Change Log
