E' uscito un nuovo firmware:
Changes made from version 3.81 to 3.90:
1. Correct accelerometer start-up error that was preventing meaningful data from being captured and reported
2. Fixed a condition where Vector could cause a display to divide by zero when receiving torque data
3. Install angle can be set in a pedal to pedal disconnected state.
4. Improved battery monitoring to make it less susceptible to sampling noise
5. Improved handling of parameter conflict between multiple displays
6. Prevent users from setting scale factor outside of the 0.75 to 1.25 range
Cosa vuol dire il punto 3.?
se posso dare un consiglio, io farei il FW upgrade se e solo se devo risolvere un problema. fosse per me sarei rimasto alla 2.8, ma mi sono fatto fregare..
per fortuna la 3.5 e' la piu stabile che ho avuto e da li non mi schiodo.
esempio sulla 3.9
https://forums.garmin.com/showthread.php?341962-Imbalance-after-3-9
Beibo
