Garmin Edge 1030
speedygabry
27 Luglio 2010
1.049
70
nella bassa dove si mangia cotechino e gnocco frit
Giant TCR Pro 2019,Giant TCR ADV SL 21
Nuova beta v.643
Changes made from version 6.30 to 6.43:
  • New Beta Feature: Galileo satellites. There is now support to use the Galileo network of satellites to assist in getting GPS fixes. With the correct GPS firmware, this option can be enabled by selecting GPS+Galileo in the GPS setting. Sync the device with Garmin Express to make sure that the new line of GPS firmware is provided to the device. Without this, the option will not be available.
  • Added support for ANT+ cycling dynamics metrics.
  • Updated smart notification categories. In the phone settings, social and other smart notification categories can be enabled. This will make the Edge show notifications from other applications depending on how they are categorized by Garmin Connect Mobile. Apps like WhatsApp, GroupMe, and Twitter may show up under social and things like e-mail, calendar, and news may show up under other. These categories are off by default and must be enabled to be seen.
  • Fixed an issue causing cadence and power data dropouts.
  • Fixed the activity profile routing mode getting reset to Road Cycling mode.
  • Fixed issues with device transfers.
  • Added prompt to indicate when a course has more course points than are supported by the device.
  • Improved Shimano STEPS response time.
  • Fixed lens mode VIRB setting.
  • Fixed issue with transmitting front and rear gear information to the Varia Vision.
  • Fixed sharp bend notifications on the Varia Vision.
  • Fixed issue with elevation back correction that could allow large dips in elevation.
  • Added the current software version to the power on page.
  • Completing a segment will now turn on the backlight.
  • Added a minimum scale to the altimeter page so that small elevation ranges are reflected properly.
  • Improved activity auto-start when the device is stationary.
  • Minor bug fixes and stability improvements.
  • Minor CIQ improvements.
giusto due correzzioni :sborone::pc::prega:
hitman80
28 Aprile 2014
97
30
San Giustino
Focus Cayo team replica force 2016
...sul mio cancello ho installato un 105 50/34 28/11 e l IQ che ho installato... sapendo i rapporti installati, la cadenza e la velocità determina in qualche secondo il tipo di rapporto utilizzato.... Non è ovviamente in tempo reale... ma comunque accettabile e fin ora ci sta prendendo...
Inviato dal mio SM-G960F utilizzando Tapatalk
Dove vanno scritti i rapporti che hai?
Inviato dal mio ONEPLUS 5 utilizzando Tapatalk
baffobaffone
18 Giugno 2013
1.516
141
Thiene (VI)
www.strava.com
OT
https://www.thisisant.com/assets/resources/FIT/FitSDKRelease_20.76.00.zip
Per esportare il contenuto di un file .fit in formato testo (.csv) utilizza i files ".bat" contenuti nella cartella "Java".
Trascina il file ".fit" sul file ".bat" interessato, la procedura parte automaticamente e si conclude in brevissimo tempo.
Troverai il file ".csv" nella stessa cartella.
In seguito potrai importare ogni file ".csv" in excel e analizzare il contenuto.
E' molto semplice :
- scarica dal sito "FitSDKRelease.zip"
- decomprimi il file ".zip"
- apri la cartella "java"
- trascina il file ".fit" sul file "FitToCSV.bat" (esporta il contenuto complessivo, puoi usare gli altri .bat per differenti estrazioni)
- apri il .csv con un editor o meglio ancora con excel
ps
Il file .csv complessivo non sarà comunque facile da interpretare.
Dovrai gestire i filtri di excel e acquisire confidenza con dati/record/campi ecc.
OT
E' molto semplice :
ps
Ok funziona,si ci sono una marea di numeri spero di capire qualcosa,ma se volessi poi da "CVS" portarlo di nuovo in fit cosa devo fare.Ottimo per modificare il file "totals" ma poi per rimetterlo nel Garmin devo riportarlo in "FIT"
carbal54
3 Novembre 2009
8.316
1.308
Sanremo
alcune :-)
Per quello che vuoi fare tu è moooooolto più semplice questo: http://garmin.kiesewetter.nl/ carichi il file .fit e te lo restituisce quasi immediatamente in .csv
Lo apri con un editor di testo io uso Notepad++, ma anche quello normale va bene o al limite Excel.
Alla riga 10 puoi leggere : data, 2, totale_dei_secondi_di utilizzo, distanza_in_metri_percorsa, totale_calorie_bruciate, , 0, numero_di_sessioni_registrate, 2,
dalla riga 11 in poi hai i dati profilo per profilo quindi sempre: data, 2, secondi,metri,calorie,nome_del_profilo, numero progressivo, sessioni con quel profilo, 2,
modifichi quello che vuoi modificare, salvi, carichi sempre su http://garmin.kiesewetter.nl/ il file .csv e ti restituisce un file _fixed.fit
Lo rinomini, cancelli l'originale sullo strumento e copi il nuovo nella cartella NewFiles.
carlo
Reactions: rosetta
baffobaffone
18 Giugno 2013
1.516
141
Thiene (VI)
www.strava.com
carlo
Se funzionasse sarebbe l'ideale,ma purtroppo da quasi sempre errore,ti dice sempre che il file è occupato da altro programma.
RicktheQuick
30 Giugno 2013
2.927
1.250
Arezzo
wilier zero.7,wilier 501
Con o senza bordo blu.
boh, per usarlo un mesetto mi va bene anche con il bordo blu, in attesa di quello restituito. ora mi sto impegnando per litigare col sindaco e la municipale per la sosta selvaggia, appena ho finito questa lite qui, comincio a litigare con garmin, che bisogna lo faccia prima di natale, quando si è tutti più cattivi!
drowssap00
2 Novembre 2009
1.205
Cosenza
Giant Defy
...sono veramente amareggiato! oltre allo schermo ormai sempre più blu (il secondo sostituito), sono settimane che non tiene più la connessione col telefono. durante l'uscita mi segnala in continuazione "rete disconnessa" - "rete riconnessa"...l'app connect mi impalla il bluetooth del telefono (esce sempre un errore "l'applicazione bluetooth si è fermata")...ho formattato il telefono ed appena ho reinstallato l'app è ricomparso il problema (problema che mi causa danni anche agli altri strumenti che utilizzo col bluetooth)...ho fatto una prova ad inserire i segmenti strava e da quando li ho caricati, nel bel mezzo dell'allenamento il 1030 si spegne...
veramente vergognoso! uno schifo
ita_2806
9 Ottobre 2013
2.227
868
Grosseto
www.flaviomencarelli.com
Bdc
A me si spengeva all’inizio del segmento. Ma secondo me il format andava fatto al 1030 e non al telefono.
drowssap00
2 Novembre 2009
1.205
Cosenza
Giant Defy
mmm...pensi che questo problema bluetooth possa essere causato dall'associazione col 1030? io ho pensato esclusivamente ad un problema dell'app, anche perchè la segnalazione di bluetooth non funzionante me la da anche con 1030 disconnesso (ma app presente). invece nessun problema con app disinstallata
Reactions: ita_2806
Franzsk
15 Marzo 2012
2.360
450
Wilier
Per l'analisi delle attività registrate(migliaia di righe e decine di colonne) dovresti importare il file .csv in Excel.
Impensabile eseguire il lavoro con un editor di testo.
Solo una cosa, prima d'importare il file in Excel caricalo in Word e sostituisci :
1) tutte le "," con ";" (delimitatore campi)
2) tutti i "." con "," (simbolo decimali)
Nella sequenza indicata, utilizza la funzione di sostituzione testo automatica, salva mantenendo il formato originale.
ma se volessi poi da "CVS" portarlo di nuovo in fit, cosa devo fare ?
Ottimo per modificare il file "totals" ...
Per modificare il file Garmin "Totals.fit" esegui prima il decode ".fit vs .csv" e poi l'encode ".csv vs .fit" .
Utilizza i due files batch (xCSVToFit.bat / xFitToCSV.bat) in allegato, posizionali nella cartella "java" .
Dovrai semplicemente trascinare il file di riferimento sopra il file .bat corrispondente.
Solo alcune accortezze :
- .csv: per modificare il Totals.csv utilizzare un semplice editor
- .csv: modificare i valori totali complessivi e i totali dei profili (obiettivo)
- .csv: sostituire tutti i valori denominati "unknown" con niente (casella vuota)
- .csv: togliere tutte le righe in eccesso che seguono l'ultima riga contenente un nome profilo
- eseguire l'encode trascinando il file Totals.csv sul batch xCSVToFit.bat
- l'encode rilascia in cartella un file denominato "Totals" da rinominare in "Totals.fit"
- caricare il Totals.fit nella cartella Garmin\NewFiles del device
ps
rinominare i files in allegato togliendo l'estensione .zip (non sono zippati)
ciao
  • xCSVToFit.bat.zip
    255 bytes · Visite: 5
  • xFitToCSV.bat.zip
    252 bytes · Visite: 5
Reactions: baffobaffone
