Garmin Edge 810
mag
19 Agosto 2012
9.993
481
Lontano da voi
solo 2
dire che l'update funziona bene sarebbe mentire
anche scegliendo metrico dopo l'update chiede il peso in libbre. facendo indietro, modificando in imperiale e rimettendo metrico, poi chiede in kg
la temperatura mostrata è in F anche se è scelto Celsius. Rientrando in menu, modificando in F, uscendo, rientrando, modificando in Celsius va a posto
In Garmin sono veramente oltre ogni insulto
BartMan
29 Maggio 2010
864
12
Masciarelli
infatti..succede pure a me, la mia altezza me la da solamente in pollici?? Boh, non riesco a convertirla in cm...continuo a dire che è un cesso (scusate il francesismo)!!:cry:cry:cry:cry
Anche a me ha dato questo problema, però sono tornato indietro, ho selezionato sistema imperiale, sono arrivato ad altezza sono tornato indietro ho riselezionato metrico ed è andato....
BartMan
29 Maggio 2010
864
12
Masciarelli
Ancora non l'ho provato ma dicono
Battery % it is correct. I fully charge it and when unplug the device , I saw 100% not anymore 98% or 97%
e
- The riding of courses seems to be, for one part, the same as in 2.5. As soon as you start a course the navigation setting switches to cycling (regardless the setting you had before) In 2.6 this issue seemed to be fixed but in reality it wasn't and actually it was worse because none of the settings enabled me to ride courses against virtual partners like all the other EDGEs did. The only way to do this in 2.6 was disabling GPS, start course, re-anable GPS with course loaded.
Now we also have the previous workaround availabe: start course, go to activiy profiel and change navigation to direct route (maybe off road as well).
One strange thing that I saw which I didn't like was that my virtual partner (on a very short course) finished before I even got to the beginning of the course, which would make the VP useless. But this might be a one time issue only.
EDIT: I did a test and there seems to be a way to get this to work without workaround. If you go to the home screen, then select the activity profile but without touching the ride button. While still in the home screen you touch the folder icon and start your course from the menu that appears, in that case the navigation settings for the activity profile do not change.
If you select ride and after that select a course with the looking glass this will tirgger the resetting of the navigation method in the activity profile.
BartMan
29 Maggio 2010
864
12
Masciarelli
testato anch'io....
Mi sa che l'unica cosa che gli interessava era renderlo totalmente compatibile con i vector....
il resto è noia
mag
19 Agosto 2012
9.993
481
Lontano da voi
solo 2
confermo, fa schifo come al solito. inoltre con la 2.70 a partire ci mette giorni. Ogni release è sempre più lenta; la 2.60 era già più lenta a tirare su le mappe al boot, questa è inaffrontabile.
mag
19 Agosto 2012
9.993
481
Lontano da voi
solo 2
da quando ho installato la 2.70 ho fatot 2 uscite ed entramne sono state "martoriate" da auto pausa e restart, auto pausa e restart ... come se sparisse il segnale gps (ho smontato il gsc10)
succede anche a voi? Che sia un problema di ricezione segnale mi pare strano; la coincidenza con la 2.70 è un po troppo precisa
mariocorto
27 Febbraio 2011
7.048
31
near Udine
TREK EMONDA SLR Sram Red 22
si è successo anche a me, ma lo faceva sempre anche prima della 2.70, andava sempre in auto pausa, soprattutto nelle zone coperte da vegetazione, addirittura in discesa mi dava 3/4 km orari di velocità, allora ho messo la pausa a 1 km/h e ho installato nuovamente il magnete per il sensore di velocità/cadenza...ora va tutto bene, probabilmente ci sono dei problemi di ricezione del segnale GPS!!
