Garmin 510
claudiodr71
14 Dicembre 2012
300
17
55
FVG
Cannondale Caad9
Salve, qualcuno sa dirmi perchè se importo i dati di una corsa su Strava non mi da il dislivello totale ? scarico gli stessi dati su Garmin Connect,Golden Cheetah e Trainingpeaks ed è tutto regolare!!!
macmanu
6 Giugno 2008
723
14
Porto Recanati
Canyon Ultimate CF SLX 2016
Per chi ha usato la nuova funzione segmenti con il firmware 3.40:
-per poter essere avvisati quando si sta iniziando un segmento,si deve seguire per forza una traccia o basta aver inserito il segmento nel 510?
merlingate
Mozzo
2 Marzo 2005
15.390
819
Riviera del Conero
Fondriest Megalu
Nuova release 3.4
https://forums.garmin.com/showthread.php?181621-Firmware-Version-3-40-Now-Available!
Changes made from 3.20 to 3.40:
New feature! Added Segment support.
To use segments, go to connect.garmin.com to find or create segments. Then, connect the device to your computer via USB cable and send the segments to your device. Once your segments have been downloaded to the device, disconnect from your computer. Then press the folder icon > Segments to access the list of segments on your device. After sending segments to your device, simply go ride through them to test the on device experience!
New feature! Added Edge Remote sensor support.
New feature! Added Shimano Di2 sensor support with Dura Ace remote controls.
New Feature! Added Vector Cycling Dynamics support that adds data fields and data recording for Power Phase (PP) and Platform Center Offset (PCO).
Improvements to the elevation profile to fit the data to the graph and display upcoming elevation while riding a course or segment.
Added a stop button on the map page. This button is used to stop a currently running course or segment and is only displayed if one of those features is in use.
Added turn guidance and off course warnings settings for courses. These can be accessed through the menu button in the bottom right corner of the course list page. (Folder icon > Courses > Menu Button)
Fixed uploads over Garmin Connect Mobile. Phone pairing information has been reset and will need to be setup again.
Made several improvements to elevation profile zooming and scrolling.
Fixed a shutdown when using 'Back to Start.'
Added options menus to the Course, Segment, and Workout lists.
Added file searching for Courses, Segments, and Workouts.
Added Time Ahead/Behind and Distance Ahead/Behind as configurable data fields on all timer loop pages.
Added the ability to edit segment map data fields.
Beibo
scusate,come si fa ad inserire il segmento?
Ciao,
qua lo spiega bene.
elioghetto
24 Agosto 2014
33
Focus Izalco Max
Con il nuovo aggiornamento ,attraversando un segmento,sul dispositivo appare oltre alla mappa, il miglior tempo, la distanza rimanente alla fine del segmento,il tempo restante al raggiungimento del miglior tempo.Qualcuno lo ha verificato?
semprefuorisoglia
sepica
10 Agosto 2004
22.561
3.452
Roma Eur
BMC slr01 TREK Madone
semprefuorisoglia
non cho fatto gran caso, ma io appena prima del segmento mi ha dato ....GO! appunto per gareggiare con il virtual patner, solamente questo, e poi un triste gingle che non ce l'avevo fatta, volevo capire qualora avessi "vinto" io avrebbe aggiornato il segmento ? ovviamente sul mio 510 ??o-o
elioghetto
24 Agosto 2014
33
Focus Izalco Max
Certo, lo aggiorna appena scarichi l'uscita sul Garmin Connect .Io invece ho notato che appena in prossimità del segmento ti avvisa in anticipo della eventuale svolta.
semprefuorisoglia
