allora devi aggiornare i vector alla 2.70
Software Version 2.70 released on the 30 December 2014
Vector software release 2.70 has been made available today.
The most significant changes are the introduction of cycling dynamics data that will be sent to head units that support the collection and display of this new information from a Vector dual sensing system.
(Note. Vector S will not send cycling dynamics data unless it is upgraded to a dual sensing system)
In this first release of cycling dynamics the following information has been added.
Add calculation and output of Cycling Dynamics, Power Phase.
Add calculation and output of Cycling Dynamics, Peak Power Phase.
Add calculation and output of Cycling Dynamics, Platform Center Offset (PCO).
This release is available via the use of the Vector Updater.
In order to collect and view cycling dynamics data you will need a cycling computer (head unit) that supports it.
The units that currently support cycling dynamics are the:-
Edge 1000 software build 2.70 or higher
Edge 810 software build 3.40 or higher
Edge 510 software build 3.40 or higher
