Qualcuno ha già provato?
non parlano di risoluzione dei problemi noti... portamo pazienza...
Changes made from version 10.00 to 11.00:
- New Feature! Added support for Shimano Di2 Synchronized Shift. Graphical Gear data fields will now blink, an alert tone will be played, and a message banner will be displayed to indicate a chain ring shift is upcoming. Synchronized Shift mode can be changed and the alert tones can be disabled through the Shimano Di2 sensor settings.
- Added improvements for ANT+ bike lights. Added new Light Beam Activated and network Light Mode settings to ANT+ Bike Lights sensor settings. You can now configure your lights to turn On with a Timer Start by using the new Light Beam Activated setting and there is also a new Trail Light Mode.
- Added support for Connect IQ version 2.2.3.
- Added segment start points to the map.
- Fixed power zone settings not being retained.
- Fixed compass text in night mode.
.... tra 5 minuti torno alla 91.
Ma non puoi chiedere a noi qualcosa che interessa solo a te. Io, in tutta franchezza, guardare la quota sullo schermo del
poi, una volta acquisito il GPS, si porta gradualmente a valori abbastanza normali -2 -3 (a abito a 1 mslm)...
