Now, one thing to keep in mind is that the gear ratio on the Elite trainers for the Zwift Cog specifically, isn’t super ideal. I talked about this a bit in my Elite Avanti review, where it’s mostly fine for 2x bikes (e.g. those with two chainrings upfront). But if you’ve got a 1x (one chainring, including the Zwift Ride), you might find the minimum floor a bit restrictive. By that, I mean the minimum wattage that you can get down to. I’ve done a *TON* of riding on Elite trainers in this configuration over the winter, as has my wife, and while it’s generally good enough, it’s just not quite ideal on a 1x bike.
This isn’t really something that Elite can directly change in terms of their trainers, however, in order to mitigate it a bit, Zwift & Elite have started to offer a different Cog that’s 18-tooth. This gives you more range from a gear ratio standpoint, helping to mitigate things a bit. I haven’t tried that variant yet, but it is now available (and listed on the store as the Elite Cog).
I suspect, long-term, Elite will tweak their gear ratios a bit on newer trainers to better accommodate the Zwift Cog situation for 1x bikes and
Zwift Ride. In the meantime, if you’ve got an older trainer (e.g. the Suito), at least Elite & Zwift are offering you options – which is certainly more than some of their competitors can say.
