Per il mio quesito del post
#177 ho mandato una mail a Lennard Zinn...è stato così gentile da rispondermi!
Gli domandavo:
"Dear Lennard,
for my cyclocross bike I would like to install a crankset MTB (eg a
Sram Truvativ X9, 42-28) with a Sram Force (10 speed). Do you think it possible? the front derailleur would work well?"
Lui mi ha risposto:
"Dear ........,
I’m willing to bet that a road front derailleur won’t shift worth beans on that setup. That’s because the curvature of the derailleur cage won’t match the curvature of the chainring. As the chainring gets that small, when you move the front derailleur down to get close to it, only the front tip of the derailleur cage will be close to the chainring; the tail of it will be far from the chainring. So the chain will not contact any of the chaped sections of the derailleur cage plates, and it will neither shift well only at the tip, nor will it control the chain well from jumping off when you hit bumps.
I tried to run 36-40 Rotor chainrings on my Campy EPS electronic ’cross bike. It was a complete disaster. Not only did I have the problem I described above, but the further problem of the ring diameter changing and getting closer to and further from the derailleur constantly made it impossible for the derailleur to do its job. It shifted in between the chainrings a lot, and it never could push it to the inner chainring.
Lennard
Thanks for your question for my column.
Keep the wheels turning,
Lennard Zinn"
Sostanzialmente la risposta è no, la curvatura del deragliatore dei gruppi da strada non funzionano bene con guarniture da 42-28. Ci sono diversi problemi sia nella discesa che nella risalita.
Ravanando comunque nel uèb, ho scoperto che i deragliatori sram da MTB sono perfettamente compatibili con i comandi indicizzati. Per cui i manettini force possono essere montati con un deragliatore X0 o X9 e funzionano correttamente con le rispettive guarniture. Naturalmente bisogna fare attenzione a quale deragliatore comprare - ma il dual pull va bene sia il cavo arrivi dall'alto che dal basso.
Peccato perchè avevo un vecchio deragliatore red intilizzato...
Ho scoperto anche che i comandi cambio
shimano 10 v sono compatibili col vecchio deragliatore shimano a 9 velocità. Nei nuovi c'è un tiraggio diverso. Ma di questa ultima possibilità non ho trovato verifiche certe, prendetela con le pinze
