Ciclisti Milanesi ....
marmoreancat
13 Settembre 2012
755
10
d'acciaio
in spagna Davide (Cassani) era con strava+iphone e faceva il doppio del mio dislivello. Che, a mia volta, era meno di quello del mio vicino di manubrio che usava il 500.
Sembra che anche l'altimetria sia una opinione :mrgreen:
[MENTION=48788]marmoreancat[/MENTION] buono a sapersi, i Vector sono sulla bici che ora e' sui rulli, quindi stasera li svito, tolgo lo spinotto, metto la chiavetta Ant+ nel portatile che porto vicino ai rulli e....aggiorno.
Cosa cambierebbe rispetto al vecchio firmware?
;nonzo%
E' cambiato parecchio...non so che versione tu abbia ma ti consiglio di aggiornare anche gli edge...
Change History VECTOR
Changes made from version 2.70 to 2.71:
Fixed messaging issue that would prevent a partially failed upgrade from being successfully retried.
Changes made from version 2.60 to 2.70:
Add calculation and output of Cycling Dyanmics, Power Phase.
Add calculation and output of Cycling Dynamics, Peak Power Phase.
Add calculation and output of Cycling Dynamics, Platform Centre Offset (PCO).
Changes made from version 2.40 to 2.60:
Removed dynamic calibration functionality. Testing of previous improvements to the static calibration routine have revealed that this feature is no longer needed.
Improved display channel start times. A timing bug was causing the display channel to only start 30s after wakeup.
Changes made from version 2.10 to 2.40:
Enabled generation and reporting of torque effectiveness (TE) and pedal smoothness (PS) data to a connected display that supports reporting this data, such as the Edge 510/810. Requires latest Edge software update.
Log an error if a crank length has been set more than 10mm different from the internally generated estimate (error 100 on Sensor Details/About page of Edge 510/810 devices). Requires latest Edge software update.
Log an error if an install angle has changed more than 5 degrees from the stored value (error 200 on Sensor Details/About page of Edge 510/810 devices). Requires latest Edge software update.
Fixed an overflow condition that was causing power and balance spikes.
Fixed a timing issue that was causing an intermittent calibration error to be reported (2/512/514).
Shortened the duration of the static calibration process from 10 to 6 seconds in most cases.
Added a mechanism that prevents multiple head units from continually resetting the crank length which was preventing power data from being reported.
Only report left sensor missing if the left side of the system is not found on wakeup or if the left pedal becomes disconnected from the pedal pod during a ride.
Changes made from version 2.00 to 2.10:
Fixed a condition where Vector may not report power or cadence for up to four minutes after performing a static calibration.
talver
2 Febbraio 2012
Segrate (Mi)
Sab Alicudi ; MTB Scott Scale Team Edition
marcomilano
5 Novembre 2010
4.434
1.492
Lombardia
www.marcogiardini.com
tutte Nere ed una azzurra
gli edge li aggiorno ogni qualvolta me lo dice Express . ma i Vector....non mi pare siano segnalati gli aggiornamenti. O sbaglio? Io credo di avere la versione precedente, quella che aggiornai credo nel marzo/aprile del 2014.
Ora toglo la pila....e controllo con la chiavetta ANT
Tu come rimani informato sul firmware dei pedali??;nonzo% Leggi i forum??
jacknipper
Diversamente scalatore
9 Febbraio 2013
16.099
15.765
Io ho strava per android e va daddio, praticamente dentro il 10% sul calcolo dislivello coi Garmin (ma dipende anche dallo smartphone che usi). Forse @fif.com usava Iphone?
so solo che in pochi mesi ha fatto il mio dsl annuale e tutto in riva al lago :mrgreen::-x como, bellagio, traghetto e ritorno .. 2500mt :wacko: ... lo Stelvio in riva al lago di como
fif.com
14 Aprile 2014
2.314
114
♣️ V3Rs+Protos, ma la NIRONE è SEMPRE nel mio ❤️
In compenso il 500 mi sovrastima (rispetto all'810 ed al 1000) il dislivello quindi anche lui non e' infallibile.
Il 500 sovrastima solo perchè non percorre le gallerie. Q ce n'è una, sale sulla montagna e scende
suggerisco strava per android ... fai una passeggiata sul lago ed hai scalato il mte bianco ... chiedere a [MENTION=67889]fif.com[/MENTION] referenze :mrgreen::-x
Pirla! Era il Garmin Forerunner 305 con altimetro non barometrico.
Io ho strava per android e va daddio, praticamente dentro il 10% sul calcolo dislivello coi Garmin (ma dipende anche dallo smartphone che usi). Forse [MENTION=67889]fif.com[/MENTION] usava Iphone?
Yes, Strava su iPhone
volendo partire alle 8.00 da Nerviano passo alle 7:00 (o poco più) così facciamo le cose con tutta calma...se preferisci vengo in camper così te la dormi un'altra oretta
Se gli altri vogliono partire dopo per scannare...ci si trova lungo la strada (io ho già stampato e plastificato il roadbook e scaricato il percorso sul videogiochi)....
E non possiamo partire alle 8:30-9:00?
Condividere traccia, pliiiiiis...
xtrncpb
8 Gennaio 2011
3.553
113
61
la mia e basta
Oggi è il compleanno di [MENTION=44887]ccqpeppè[/MENTION] (Dott.Comm.)
Non so se leggerà il Forum. In ogni caso...
TANTISSIMI AUGURIIIIIII !!!!!!!
o-o o-o o-o o-o o-o o-o o-o o-o o-o o-o o-o o-o
suipedali
1 Settembre 2011
771
25
MilanoSudEst
da strada & fango
Ciao, sabato e domenica c'è qualcuno/qualche gruppo che parte da Milano (zona sud/sud-est/est) a cui potersi aggregare?
grazie!!!
sabato ore 9:00 via mecenate al 60 (subito dopo i campi da tennis)
gruppone, 70 km ad andatura variabile, dai 30 a 35 di media, dipende.
domenica: Nh Hotel milano 2 ore 8:00 (di solito) gruppetto della sezione Ciclisti Milanesi che va in brianza.
Dai 70 ai 100 km ad andatura variabile con qualche salitella.
