Garmin Edge 520
matrug
10 Gennaio 2006
3.347
229
66
Campania
Storico: PINARELLO Surprise e Marvel, LOOK 486-595-695 SR, Giant Tcr Adv e Sl, Propel
Aggiornamento alla versione 3.10, ecco, in inglese, le modifiche:
Change History
Changes made from version 3.00 to 3.10:
  • Improved Varia bike light network performance when using multiple lights and a radar. Update your Varia Rearview Radar to software version 3.00 or greater to take advantage of this.
  • A new Radar sensor type has been added and new radar settings are available under Sensor Details that allow you to control radar tones, color overlay, and vehicle column position. These settings are available only after updating your Varia Rearview Radar to software version 3.00 or greater.
  • Reduced radar overlay obstruction while you are stopped and trying to use the menus.
  • Improved the light sensor menu and refined light mode options, adding a high visibility mode.
  • Added an improvement to simplify changing segment goals during a ride. While the message that you are approaching a segment is displayed, press the Enter (top-right) button to immediately bring up the page to change the segment goal type.
  • Added a toggle for workout target zone alerts. Go to Menu > Settings > Activity Profiles > [Profile Name] > Alerts. 'Workout Target Alerts' will control whether or not you see alerts for being outside a target zone value during a workout while using this profile.
  • Added the ability to take pictures with a connected Virb. This item appears on the Status page with the Virb recording control.
  • Added the option to always receive a prompt to calibrate a paired power meter when the Edge 520 finds it and the timer is not running. Go to Menu > Settings > Sensor > [Power Meter] > Sensor Details. 'Calibration Prompts' will control this setting on this power meter.
  • Updated the Auto Sleep time to five minutes.
  • Fixed a bug preventing alert pages from displaying correctly in night mode.
matrug
10 Gennaio 2006
3.347
229
66
Campania
Non sono una cima in inglese quindi mi sono affidato ad un traduttore online:
Miglioramento delle prestazioni di rete Varia bici luce quando si utilizzano più luci e un radar. Aggiorna il tuo radar Varia retrovisore alla versione software 3.00 o superiore per approfittare di questo.
Un nuovo tipo di sensore radar è stato aggiunto e nuove impostazioni del radar sono disponibili in Dettagli del sensore che permette di controllare i toni radar, sovrapposizione del colore, e la posizione della colonna di veicoli. Queste impostazioni sono disponibili solo dopo l'aggiornamento del radar Varia retrovisore alla versione software 3.00 o superiore.
Riduzione del radar overlay ostruzione mentre si è fermato e cercando di utilizzare i menu.
Migliorato il menu sensore di luce e raffinate opzioni della modalità luce, l'aggiunta di una modalità ad alta visibilità.
Aggiunto un miglioramento per semplificare la modifica degli obiettivi del segmento durante una corsa. Mentre è visualizzato il messaggio che si sta avvicinando un segmento, premere il pulsante Invio (in alto a destra) per portare subito la pagina per modificare il tipo di obiettivo segmento.
Aggiunto un ginocchiera per gli avvisi di zona bersaglio allenamento. Vai a Menu> Impostazioni> Modi attive> [Nome profilo]> Avvisi. 'Allenamento Bersaglio Alerts' controllerà se o non si vedono gli avvisi per essere al di fuori di un valore target zone durante un allenamento durante l'utilizzo di questo profilo.
Aggiunta la possibilità di scattare foto con una virB collegato. Questa opzione viene visualizzata nella pagina Stato con il controllo di registrazione virB.
Aggiunta la possibilità di ricevere sempre una richiesta di calibrare un misuratore di potenza accoppiato quando il bordo 520 lo trova e il timer non è in esecuzione. Vai a Menu> Impostazioni> Sensore> [Power Meter]> Dettagli Sensor. 'Taratura Prompt' controllerà questa impostazione su questo misuratore di potenza.
Aggiornato il tempo Auto Sleep per cinque minuti.
Corretto un bug impedisce pagine di avviso corretta visualizzazione in modalità notturna.
andrea2712
13 Settembre 2015
69
Bianchi
Ciao a tutti
io ieri dopo tanto che nn ci riprovavo ho cercato di seguire un percorso caricato nel Garmin 520 ma come segnalato qualche mese fa nn sono riuscito, mi da sempre fuori corsa...
Avete anche voi ancora questo problema?
micchei
29 Marzo 2009
822
22
Trento
una BDC, una TT e una MTB
Ciao a tutti
Non mi é mai capitato. Mi viene da pensare che tu stia usando file di dubbia precisione. Prova a fare una prova: segui un percorso generato dal tuo stesso strumento, a qualche giorno di distanza, alla stessa ora; se vai fuori rotta vuol dire che c'è qualcosa che non va nel tuo edge. Se tutto ok allora sarà il file scaricato farlocco.
Sent from my Aifon using Tapatalk -
andrea2712
13 Settembre 2015
69
Bianchi
Ciao Micchei
i percorsi caricati del Edge 520 li ho fatti tramite Garmin Connect dalle mie attività come ho sempre fatto anche quando avevo il Edge 500.
Nn saprei quando ho due minuti cancello tutti i percorsi creati sia dal sito che dell 520 poi li rifaccio da capo e li carico di nuovo del dispositivo e vediamo...
Deviz
19 Aprile 2015
736
9
Aviano
Specialized Tarmac SL4
una domanda....se si utilizza la funzione segui percorso con relativa "navigazione"... diminuisce di molto la batteria???
Inviato dal mio ASUS_Z00LD utilizzando Tapatalk
Dav#76
1 Marzo 2008
3.533
Cercenasco
Trek Emonda SL
Provo a fartelo io... Solo Lombardia?
Mandami in MP la tua mail che appena mi arriva il file te lo giro immediatamente già con il nome corretto... Mi raccomando salvati il file originale del garmin.
Dav#76
1 Marzo 2008
3.533
Cercenasco
Trek Emonda SL
di che colore l'hai preso?...hai una foto, così mi faccio una idea di come ci stia sopra.
...io per il momento ho solo preso la pellicola trasparente per il display su ebay
