Ruote ICAN: qualcuno si sta trovando molto bene...
tubinpa
15 Ottobre 2014
861
Verona
Specialized Tarmac SL8 PRO
Buonasera,
Da qualche parte qualcuno ha trovato info su quale sia la misura minima di copertoncini che si può montare sulle Ican/imust con canale 18,35mm?
Su aliexpress indicano solo la Larghezza massima dei copertoni, di 28 mm, ma non la minima.
davlak
30 Giugno 2011
10.204
713
fiumicino
3 Cannondale
Buonasera,
sulle IMUST stesso cerchio indicano la misura consigliata minima 25
https://www.amazon.it/IMUST-Carboni...qid=1507135777&sr=1-1&keywords=imust+tubeless
d'altra parte il cerchio è largo e metterci su qualsiasi cosa meno di 25 mm mi sembra azzardato.
davlak
30 Giugno 2011
10.204
713
fiumicino
3 Cannondale
il primo commento "negativo" sulle ICAN è di ieri:
"I was skeptical in writing this review and if I should put one, two or three stars!! In fact it's my second experience with ICAN, and obviously none of them was successful. Last year I tried ICAN 50 and everything was fine until the spokes start breaking . As for the new version the FL40, I was so excited to get them, because they were wider, and had Sapim Spokes !!! their weight was fantastic and they looked much better than the old version. The main reason I'm giving two stars is that it's almost impossible to mount and unmount tires on those wheels!! Now I have to say that I have 3 other sets of wheels ( different brands) and I ride about 6000 miles per year; so I'm familiar with changing/mounting/un-mounting tires !! It took me more than an hour to mount a 25 Conti 4000 on the rear wheel using 3 Tire Levers, and I gave up for the front wheel. after riding for a short distance, considering the hassle in mounting the tires, I decided to return them, and there was my BIGGEST surprise, un-mounting them was even harder !!! I thought if I have a flat on the road my only option is UBER !!! I do believe ICAN are doing their best to improve their products, but always there is the "BUT" !! I tried to ask questions and got no answer except an old video for the older version of those wheels!! Unhappy to have two bad experiences... with a product that has the potential to be "Very Good'"
ma è una lamentela sulla difficoltà di montare pneumatici su queste ruote ;nonzo%
a me sinceramente non è sembrato tutto sto casino che ha descritto il tizio.
si, è vero, sono un pò ostiche soprattutto con dei tubeless come i pro one, ma ho visto di molto ma molto peggio!
tubinpa
15 Ottobre 2014
861
Verona
Grazie Davlak.
Io come scritto in altro thread ho messo anteriormente una una GP4000 da 23 che fa Larghezza effettiva 25,5.
È l'unico copertone che sta dentro la forcella della bici muletto che sto adoperando in questi giorni.
L'ho già usata per 90 km.. Dici che sono a rischio? Conta la Larghezza nominale da 23 o quella effettiva da 25.5?
davlak
30 Giugno 2011
10.204
713
fiumicino
3 Cannondale
Grazie Davlak.
beh, in questo caso forse conta più che altro la dimensione effettiva, visto che il dato dei 25mm è "consigliato" e peraltro sul sito del costruttore non mi pare ci siano restrizioni a riguardo
https://www.icancycling.com/products/40mm-straight-pull-wheelset-fast-light-series
zirbaf
28 Maggio 2010
787
137
varese
willier 101sr red r-sys slr
[MENTION=35417]davlak[/MENTION]...sono un pò ostiche soprattutto con dei tubeless come i pro one.
(non mi quota).
anch'io probabilmente me le regalerò per natale:bn: quelle con profile da 40
ti chiedo quale alternative consiglieresti ai pro one di tubeless più "morbidi" nel montaggio?
uso anch'io i pro one sulle mavic r-sys e nessun problema nel montaggio, mentre sulle vision trimax30 2015 non c'è stato verso di farli salire
pcat
1 Luglio 2017
24
Bianchi
Sono comparse come "spedite da Amazon" le Imust 38 con raggi Sapim, 100 grammi più leggere di quelle che ho preso io (1350 invece che 1450). All'epoca dell'acquisto le avevo scartate in quanto esclusivamente vendute e spedite da Imust: tempi molto più lunghi di consegna e soprattutto assenza della garanzia Amazon. Noto inoltre che spedite da Amazon costano 455 invece che 479.
Sarei orientato a rendere quelle che ho (sono ancora in tempo) e a investire meno di 60 euro per delle ruote uguali ma con raggi migliori e 100 grammi più leggere. Voi che dite?
Mi riferisco a queste:
https://www.amazon.it/IMUST-Carboni...=UTF8&qid=1509380445&sr=8-3&keywords=imust+38
Le mie sono invece queste:
https://www.amazon.it/IMUST-Carboni...=UTF8&qid=1509380445&sr=8-2&keywords=imust+38
MiloD
23 Giugno 2014
1.155
983
Trigolo (CR)
".... The main reason I'm giving two stars is that it's almost impossible to mount and unmount tires on those wheels!! ...It took me more than an hour to mount a 25 Conti 4000 on the rear wheel using 3 Tire Levers, and I gave up for the front wheel...'"
Io ho le 40mm e ho provato a montarci un Conti Grandprix usato e sinceramente non c'è stato verso...
Solitamente riuscivo a montarlo a mano sulle vecchie.
Ma però non le ho restituite :mrgreen:
Simone.01
2 Luglio 2014
5.826
401
Trek Emonda SL6
Sbagli o entrambe non sono TLR?
davlak
30 Giugno 2011
10.204
713
fiumicino
3 Cannondale
:mrgreen:
boh...io ci ho montato i PRO ONE con una certa fatica, ma per dire...ne ho fatta di più su altre ruote.
certo che se arrivano coi raggi lenti, allora ci può anche stare che è dura far salire il pneumatico.
forse sarà proprio per questo, che io non ho avuto grossi problemi, dato che ho tensionato da subito i raggi a entrambe le ruote appena arrivate.
davlak
30 Giugno 2011
10.204
713
fiumicino
3 Cannondale
io se fossi in te renderei le tue e prenderei quelle col cerchio nuovo a disegno toroidale U-Shape.
per intenderci, queste.
https://www.amazon.it/gp/product/B06XBTL77J/ref=ox_sc_act_title_1?smid=A30YETFWKA49T1&psc=1
o al limite anche queste coi PILLAR
davlak
30 Giugno 2011
10.204
713
fiumicino
3 Cannondale
Io sto per ordinare queste, che ne dici?
Ovviamente da pirla quale sono ho omesso di allegare il link... mi riferivo a queste...
ICAN FL50 Ruote Corsa Carbonio 50mm Copertoncino Tubeless Pronto AS511SB/FS522SB Mozzo Sapim Raggi https://www.amazon.it/dp/B01E0QZYD2/ref=cm_sw_r_cp_api_IAA-zb4H2DC7J
in pratica le stesse di cui si parla, ma con profilo 50.
belle!
anche se io personalmente trovo eccessivo per me quel profilo.
tubinpa
15 Ottobre 2014
861
Verona
Io ho le Imust da 50mm da 10 gg.
Ho fatto circa 300 km e sono contentissimo, anche della scelta del 50 invece di 40, visto che anche io ho avuto quel dubbio. Poi ho valutato solo per estetica il 50mm, anche perché venivo le 42 le avevo già avute e volevo cambiare.
Ad ogni modo non sono per niente pentito, anzi, due giorni fa ho fatto un giro di 80 km con molto vento sia contrario che laterale e devo dire che pensavo sarebbe stato molto peggio. Invece anche con le folate non mi è mai successo di essere in difficoltà o di temere alla stabilità della bici. Ovvio bisogna tenere stretto il manubrio ma niente di che.
Ora mi metti il dubbio... [emoji23][emoji23][emoji23]
davipower
22 Ottobre 2014
261
33
San Salvo (CH)
Focul IZALCO MAX
Ottimo....:) come ti trovi?? Frenata? Scorrevolezza? Le hai montate con la camera d'aria o tubeless? :)
tubinpa
15 Ottobre 2014
861
Verona
Io mi trovo da dio.. Montate tubeless Pro One sono stra comode. La frenata è ottima, come scrivevo qualche post fa. Ieri ho montato i pattini Aztec suggeriti da qualche forumista, frenano bene, ma stamattina fischiavano molto nelle frenate più marcate in discesa. Proverò a montarli convergenti.
In generale cmq mi trovo molto bene. Per ora confermo rapporto qualità prezzo davvero ottimo
davipower
22 Ottobre 2014
261
33
San Salvo (CH)
Focul IZALCO MAX
Perfetto...:) io penso di prenderle entro fine mese...non vedo l'ora...!! 😍
