uno e' di scorta , possibile che non lo sapete...se non vi entra un marcia ne avete una scorta oppure quando pensate di averle finite tutte...voilà ne esce una magicamente....
ragazzi ma c'è scritto sul primo pignone 10s 12 e sull'ultimo 25 quindi 12-25 10 speed
per riuscire a vedere tutti gli 11 rapporti ci vorrebbe una foto da un'altra posizione..................
Cmq l'11 v è in vendita tra un mese.
Roues Artisanales:Come lo sai? Dove l'hai letto? Come mai Campagnolo non lo sa?
Roues Artisanales:
Despite the embargo Campagnolo fixed until the 18th of June on the 2009 groupsets, which is tomorrow, some websites already published the official pictures of the Super Record 11 speeds groupset. We take the liberty to unveil these first pictures, a couple of hours before the expected date.
The Campagnolo Super record groupset will be at the top of the italian range, just above the standard "Record". The expected price is 2300 euros, against 2000 euros for the normal Record. The three top range groupsets, to know Super Record, Record and Chorus, will feature an eleventh speed. The rotor width will be similar to the current 10s versions, which is pretty good for compatibility, however, the chain will be narrower. The carbon fibre will be present on almost every parts, the ceramic and titanium will be present too on the pulley wheels and screws.
The levers are dramatically changing shape on the whole range, they are higher and face the interior of the bars.
Cycling Weekly:
Campagnolo 2009
As we reported last month, Campagnolo has gone one better than the competition and launched 11-speed road components.
A select group of journalists was invited to the Croce d'Aune, Italy, at the weekend to see the new components and get a chance to give them a ride.
Three top-end 2009 Campagnolo groupsets will receive the 11-speed treatment - Super Record, Record and Chorus. Centaur and Veloce remain 10-speed. For now.
According to Campagnolo, every transmission component in the 11-speed groups was redesigned. This includes the Ergopower levers, front and rear derailleurs, chain, cassette and crankset. Campag's engineers have improved the stiffness of the rear derailleur, with the aim of making more precise shifts.
The re-appearance of a Super Record groupset, a super-lightweight and quite probably super-expensive version of the already lightweight Record group. Super Record will use titanium parts to shed weight and increase component life.
The new 11-speed cassettes are available in 11-23, 11-25, 12-25 and 12-27 ranges. Although Campagnolo have not confirmed it, it appears that cassette should fit a 10-speed hub, and therefore most current wheelsets.
Other than just accommodating the extra gear, Campag's Ergopower levers receive a significant update, with hoods sitting higher on the bar in accordance with riders' current preference. Internal parts have also been tweaked to improve performance.
Magari non e' tra un mese, ma per arrivare arriva.
E' bellissimo.
copia/incolla dal sito Roues artisanales !!! http://www.rouesartisanales.com/article-20531304.htmlDa quello che leggo, se non erro, ci sarebbe questo Super record 11 v con tutti i componenti nuovi tranne mi sembra i freni e sarebbe una versione superleggera del record che mi sembra diventerebbe anch'esso a 11 v. Sbaglio ? E mi sembra di avere letto che sebbene la ditta non lo abbia confermato pare che questo 11 v sia compatibile con le attuali ruote con il corpetto a 10 v. Sbaglio ?
A questo punto a parte il centaur e il veloce che rimarrebbero a 10 v, dal catalogo della ditta scomparebbe definitivamente il 10 v. Giusto ?
Addio caro 10 V. Amen![]()
Campagnolo Super Record
En dépit de l'embargo sur les nouveautés Campagnolo 2009 jusqu'au 18 juin, soit demain, certains sites ont déjà mis en ligne plusieurs photos officielles du groupe Super Record 11 vitesses. La surprise est à moitié entamée et nous nous permettons donc de dévoiler aussi ces premières photos, quelques heures avant la date prévue.
Le groupe Campagnolo Super Record très haut de gamme se placera donc au dessus du groupe Record pour un tarif annoncé à près de 2300 euros contre 2000 euros pour le Record "simple". Il disposera donc de 11 vitesses, le Record "simple" et le Chorus aussi. A priori, la largeur de cassette est conservée ce qui est de bon augure pour la compatibilité, mais la chaîne s'affine. Le carbone se taille la part du lion sur ce groupe mais la céramique et le titane s'offrent plusieurs places de choix sur les galets et la visserie.
Les leviers changent radicalement de forme sur toute la gamme, ils s'avèrent plus hauts et reviennent vers l'intérieur.
Et voilà...Abbi pietà di me
Me lo traduci perchè ho finito le mie risorse
Merci![]()
Et voilà...
Il gruppo Campagnolo Super record molto di gran lusso si metterà dunque sopra il gruppo record per una tariffa annunciata quasi a 2300 euro contro 2000 euro per il record semplice. Disporrà dunque di 11 velocità, il record semplice e Chorus anche. A priori, la larghezza di cassetta è conservata ciò che è di buon augurio per la compatibilità, ma la catena si raffina. Il carbonio si taglia la parte del leone su questo gruppo ma la ceramica ed il titanio si offrono molti posti di scelta sui rulli ed il visserie.
Le leve cambiano radicalmente forma su tutta la gamma, risultano più alti e ritornano verso l'interno.
certo ke 2300 euro per il super record sono davvero tanti.
Esatto...da quello che dice Roues Artisanales, il Record "semplice" e il Chorus saranno a 11 velocità...O qua ti volevo: il record rimarrebbe in catalogo ma sarebbe solo prodotto a 11 v e non più a 10 v . Sbaglio.
Rispondimi in italiano :asd::asd::asd:
Grazie![]()
Quelli sono prezzi da listino !!!E che ne pensi del prezzo del record 2009 ?
...........sperooooooo...Quelli sono prezzi da listino !!!...........sperooooooo...[/quot
saranno compresi i mozzi ,pedali etc...bisognerebbe vedere il prezzo a 8 pezzi......
