Rapasave
2 Giugno 2009
12.752
697
Alto Adige - Süd Tirol
Ciao [MENTION=16109]Rapasave[/MENTION] ,
mi ha scritto ifor ; mi ha comunicato che ha individuato dal log il punto in cui perde il segnale ma non riesce a capire quale sia il motivo.
Comunque ha individuato un bug in ipsensorman e lo dovrebbe sistemare a giorni...
Ecco la risposta:
OK Thanks for the logfile.
I found the bit where the first issue occurs. It’s not clear why the issue happens but basically I get a message about each sensor in turn from the underlying system indicating that the channel is closing. I presume something bad has happened to the underlying driver system. IpSensorMan itself is not being asked to close or anything like that so the root cause is unclear. IpSensorMan waits 5 seconds (this is new for 1.3.8) then tries starting the channels up again. They look to start back up again but then IpSensorMan looks to be confused and decides that they were not wanted. This is clearly an issue with my code with regard to the retry in the event of an error. I will review it and look to get you a version with a fix in to try. May be a day or two depends how obvious the situation is.
Ifor
ciao
Ottimo Manuel....speriamo risolva presto!
inviato tramite il mio Samsung S5 Ipbike powered!!
twinmaster
9 Gennaio 2015
62
canyon
ho provato e funziona!! (vedi screenshot)
ovvio che dev'essere calibrato e configurato.
Ho provato 2 volte giusto per sicurezza, ma alla seconda prova l'app è andata in crash su i 2 smartphone che stavo utilizzando. Ho inviato il report allo sviluppatore.
    107,9 KB · Visite: 32
    48,9 KB · Visite: 22
    144,4 KB · Visite: 23
twinmaster
9 Gennaio 2015
62
canyon
La risposta di Ifor.
OK. I am not totally clear what ANT Protocols the trainer is transmitting. If it’s transmitting standard ANT+ Speed or Power then they should work, you should see devices show up in IpSensorMan for them that you can associate with a bike in IpBike. Try doing the search again for more devices. If it’s only transmitting the F-EC trainer control protocol which it looks to be then that is as yet unfinished in IpBike and IpSensorman. I have put the first go at stuff into IpSensorMan but it’s all untested with real hardware although it looked OK with simulation. I just bought a new trainer myself to enable me to do the proper work needed in IpBike. I did see a crash report appear for a trainer which I guess is from your crashs. I will be looking at things hopefully in the next few days. I will get back to you once I have something new to try.
Inviato dal mio SM-N9005 utilizzando Tapatalk
Rapasave
2 Giugno 2009
12.752
697
Grande Ifor...sempre disponibile!!
stamattina ero in bici...tanta umidità...se non avessi avuto uno smartphone impermeabile non so se sarebbe sopravvissuto....
Secondo me per uso ipbike...impermeabilità e barometro devono essere presenti nello Smartphone
twinmaster
9 Gennaio 2015
62
canyon
Mi ha inviato anche la nuova versione di ipsensorman con la correzione del bug..
Thanks for the crash report. I have fixed that specific bug in the version attached. It’s still not going to let you control the trainer from IpBike but hopefully it want crash as quickly. In theory you could try setting the resistance from in IpSensorMan once connected long press and there is a menu option for setting the resistance.
I should be getting real support working soon I will keep you updated
oberti
29 Maggio 2008
1.559
104
Bunat Sura ( BG )
Con 2 ruote.....
Anche a me ma per altri problemi.......è la versione 1.3.8.1 ???
ciao ciao
Rapasave
2 Giugno 2009
12.752
697
Si integra alla perfezione con ipbike, ho pagato 350 euro l'SL+ con la ruota completa di pignoni e gomme anche se due cuscinetti posteriori hanno gioco e sono da cambiare.
Esiste un tutorial postato da qualche parte ( youtube) per la sostituzione fai da te, diversamente portarlo in assistenza per il cambio cuscinetti e taratura costa un occhio della testa e precisamente 180-200 eurini.
Il mio consiglio in caso di acquisto è di visionare la ruota montata sulla bici, solo così puoi evidenziare il gioco dei cuscinetti, che è il punto debole del powertap che per il resto è decisamente affidabile, la sostituzione pile ( rigorosamente all'ossido di argento le altre non durano nulla) è estremamente semplice.
Considera anche che la ruota pesa 400 gr in più, quindi è adatta per solo allenamento.
Ciao per cambiare la.batteria è difficile al modello sl? Ci vogliono chiavi speciali?
oberti
29 Maggio 2008
1.559
104
Bunat Sura ( BG )
Con 2 ruote.....
Risolto Manuel?
Ciao [MENTION=16109]Rapasave[/MENTION],
la nuova versione sembra funzionare.........( mi sto grattando :) )
Nelle uscite di sabato e domenica nessun problema.
Io comunque per sicurezza ho sostituito pure la batteria al cardio , non so quanto duri , ma la batteria fino a sabato ha sulle spalle circa 1200hr di funzionamento.
Matteo
21 Ottobre 2006
980
17
Erba
www.caedevice.net
Merida Road 901
[MENTION=4297]Matteo[/MENTION] hai poi montato il front mount sulla Bici ?
Potresti postare le foto con il tuo cell ??.....Mi sa che a natale lo prendo anche io
GRAZIE
CIAO CIAO
Ciao, ho chiuso la stagione a fine settembre perché sono stato investito da una carrozzina elettrica!!! Non mi sono fatto niente, ma ho un cerchio piegato di 90° (e forse un po' anche il telaio)... in attesa di riparare la bici (e quindi di montare il front mount) mi dedico al running, quindi.. ci vediamo (con il front mount) tra un paio di mesi :)
oberti
29 Maggio 2008
1.559
104
Bunat Sura ( BG )
Con 2 ruote.....
Rimettiti al più presto
o-oo-oo-oo-oo-o
