Grazie [MENTION=5068]mapie[/MENTION]
Ci sono finalmente le funzioni che aspettavo... Mi sa che a questo giro faccio da beta tester!
Changes made from version 7.00 to 8.00:
Varia
Vision users: Please update to the latest version of Varia Vision software to maintain compatibility with your
Edge.
Added support for ANT+ shifting, enabling the
SRAM RED eTAP and Campagnolo EPS systems. You can now view current gear information such as gear ratio and battery status directly on your device.
Added compatibility with the new WKO4 Coggan individualized power levels (iLevels) by TrainingPeaks. Users can now update their iLevels directly from WKO4 by syncing through a USB connection. To change between using seven power zones or nine Coggan iLevels, go to My Stats > Training Zones > Power Zones > Configuration.
Added the following features from the Edge 520:
Indoor trainer support
Independent GPS modes for activity profiles
FTP test workout
Auto-FTP calculation
Auto-Max HR calculation
VO2 Max calculation
Recovery advisor
Fixed an issue with segment leaderboard and weight file syncing through
Garmin Connect Mobile.
Changed the 'Gear Ratio' data field to be expressed as the front gear size divided by the rear gear size. For example, 52-11 is now 4.7. You can now view the size expressed in gear teeth with the new 'Gear Combo' data field.
Added support for the Connect IQ smartphone API for CIQ developers.
Fixed editing CIQ data field settings on Garmin Connect Mobile.
Improved the software update process by skipping the initial setup wizard after completing an update.
Added Firstbeat settings file storage to allow the VO2Max value to be preserved when updating software.
Changed call and text prompts to require a key press to dismiss so they are not missed.
Fixed issue with course
time for Garmin Connect courses.
Fixed activity review for rides recorded without location information (indoor rides).
Improved direct routing and Back-to-Start.
