Telaio in grafene
Bruno Rabolini
15 Luglio 2016
210
21
Merida CWU
Il talaio potrebbe pesare non oltre i 350 grammi
http://www.cyclingweekly.co.uk/news/product-news/dassi-graphene-frame-260002
Se fosse già stato pubblicato, chiedo in anticipo ai moderatori la cancellazione dell'argomento.
Grazie, Bruno.
patroclo
8 Aprile 2015
2.404
27
torino
1 merida disc 3000 2) acciaio spirit Potenza 3) acciaio spirit Gravel disco in arrivo
schillaci
27 Febbraio 2010
605
graziella
Leggendo sotto....
What exactly is this frame made of?
Is the frame made completely from graphene? Well, no.
The frame contains just a minimum 1 per cent of the material, which is hooked together with an epoxy resin and later layered with one level of carbon-fibre. Is it the lightest frame we’ll ever see? Not this one, as the first frame presented weighs around 750 grams, which is actually the same weight as the frame of the Pinarello Dogma F8Xlight that Chris Froome is riding at the Tour de France.
At the presentation of the new graphene frame, Dassi CEO and founder Stuart Abbot (a former aerospace design engineer for Rolls Royce) said that the weight of the frame could go down of a further 200 grams in the future. And further down the line, Dassi claims that it could be able to present a 350g frame, but there are issues with the layering process that need to be ironed out (the graphene sheets were narrower than expected and harder to work with) meaning that for now their frames composed of six layers of graphene composite material on the inside, and one layer of carbon-fibre on the outside
Bruno Rabolini
15 Luglio 2016
210
21
Merida CWU
chiedo al tecnico , non al ciclista appassionato ; cosa e' il grafene ?;nonzo%
Entro su un campo minato, ne so veramente poco.
La più recente innovazione in campo bdc è stato con i tubolari Vittoria in grafene, veramente interessanti.
Non ho voglia di andare su wikipedia, quindi vado a braccio. Questo materiale, sviluppato da due ricercatori russi presso l'Università di Glaslow e per il quale hanno ricevuto il Nobel per la chimica se non erro nel 2006 (poi vado a vedere, magari ho preso un granchio colossale), consiste di una struttura a base di carbonio disposta su un piano monodimensionale a struttura esagonale. Ha trovato applicazione sia per la pulizia della superficie delle acque (inquinamento) che per i display flessibili. Incredibile.
Il maggior prodiuttore di grafene penso sia in Lombardia (ma potrei sbagliare).
Insomma, c'è di che entusiasmarsi.
Scusa per il pistolotto.
Ciao, Bruno.
patroclo
8 Aprile 2015
2.404
27
torino
Ciao, Bruno.
uauuu....grande Rabolini . non lasciarci , rimani qui' ti prego.o-o
Ser pecora
Diretur
Membro dello Staff
16 Aprile 2004
28.778
45.016
100
dove capita
Su 750 grammi mettiamo che 500 siano di grafene
(500/5)x700 = 70.000 verdoni. Ricarichi e tutto, meno di 250.000 dollari non lo paghi.
Salto....
In realtà non funziona cosi'. Il grafene (o altri nanomateriali del genere) vengono usati per migliorare le caratteristiche della fibra di carbonio utilizzandone quantità minime.
Al momento restano cmq troppo care.
mika
Pink makes you faster
9 Novembre 2007
21.450
1.970
San Giorgio di Nogaro (UDINE)
BIXXIS "PRIMA XL"
Non è comunque un qualcosa per la quale i costi di progettazione/produzione negli anni di possano ammortizzare con una diffusione ampia, oppure potrà avvenire solo in maniera parziale, mi sembra di capire, viste le procedure di estrazione.
Ser pecora
Diretur
Membro dello Staff
16 Aprile 2004
28.778
45.016
100
dove capita
Un produttore italiano ha provato ad utilizzare il fullerene su un proprio telaio con risultati eccezionali in termini di maggior robustezza a parità di peso. Per ora è troppo caro, ma arriverà tra qualche anno.
mika
9 Novembre 2007
21.450
1.970
BIXXIS "PRIMA XL"
Se lo godranno le generazioni future allora. Ormai sono vecchio o-o
Comunque sarà un progresso importante.
tombazosana
31 Dicembre 2010
2.849
7.472
veneto
da corsa
Non servono a niente.... solo a far ingrassare il commerciante di turno visto a debacle che stanno avendo contro i telai cinesi....
si parte piano e dopo si rallenta..
flavio-resana
16 Ottobre 2009
11.056
928
Resana (TV)
Bianchi Specialissima CV
Comunque prima dell'inverno prenderò i nuovi Sci Head WC Rebels I-Speed Pro con Graphene..vediamo rispetto ai miei vecchi WC come vanno. Non sò che riferimento possa essere, ma sempre di G si parla.
per esperienza personale (sci di alto livello in quanto facevo gare poi mollato per mancanza di fondi...).
Quando iniziai ero nel passaggio dallo sci "normale" a quello con soletta in graffite e nuovi tipi di lamina, e nuove sciancrature...
purtroppo non mi sono poi evoluto nella sciata "Moderna", ma viaggio, nonosante tutto, a fare tempi quasi ai top dei master e senza materiale top di gamma.
Il grafene, a detta degli esperti, non aiuterà moltissimo in termini di prestazioni, forse più leggeri gli sci e solette più prestazionali, ma il grosso della partita si giocherà sul ritorno a Raggi più corti.:mrgreen:
http://www.skiforum.it/forum/showthread.php?t=82277
ottimo commento sul post degli sci Head...
effettivamente il grafene sembra solo una trovata.
mika
9 Novembre 2007
21.450
1.970
BIXXIS "PRIMA XL"
OT
Vedremo.
Raggi più corti...se c'è pista libera il GS lo deformi. Se ti vuoi divertire nel traffico un raggio 15 è sufficiente. Elan Amphibio 16, per divertirsi il top.
FINE OT
