Vittoria corsa Graphene 2.0 tlr
36.311
27.146
36.311
27.146
mi sa che sono due pneumatici diversi anche se della stessa ditta e venduti dallo stesso negozio, controlla bene, prima di :maestro:, whisp !mabbasta!;:smackbutt
Technical specifications:
Tire Type: Folding / Clincher
intended use : road bike, triathlon
Size (inches): 28 | 700x25C
Size (ETRTO): 25 - 622
Execution: Corespun carcass, TL Ready, Chevron profile
Compound: Graphene 2.0, 4 C Compound
Carcass: 320 TPI
tubeless capable: yes
Compatibility E-Bike: N / A
Profile: Race oriented with longitudinal grooves, laterally profiled chevron tread
recommended air pressure: max. 9.0 bar (130 PSI)
Recommended rim width: 15-20 mm
Maximum load: not specified
Color: black / black
Weight according to the manufacturer: 300g
Weight weighed by yourself: 309g
Version: Corespun carcass, TL Ready
Carcass: 320 TPI
Profile: Race oriented with longitudinal stretches
Weight according to the manufacturer: 290g
Weight weighed: 285g
Note: The weights of the tires may vary due to production!
E dove le trovi le differenze ??
;nonzo%
sheik yerbouti
i'm voodoo child
8 Dicembre 2013
18.165
9.318
disc
Carcass: 320 TPI
Carcass: 320 TPI
;nonzo%
vabbe' te lo spiego ora e poi non te lo dico piu'
quello segnalato da tony e' il vittoria corsa control pneumatico da pave'
https://r2-bike.com/VITTORIA-Tire-Corsa-Control-28-700-x-25C-Graphene-20-4C-TL-Ready-black-black
https://www.vittoria.com/eu/corsa-control-competition-race.html
c'e' anche scritto sullo pneumatico, corsa control,
questo segnalato da me e' il corsa,
https://r2-bike.com/VITTORIA-Tire-Corsa-28-700-x-25C-Graphene-20-4C-TL-Ready-black-black
https://www.vittoria.com/eu/corsa-competition-race.html
sullo pneumatico c'e' scritto solo corsa,
qui puoi vedere i 3 modelli di tlr vittoria, corsa, corsa speed e control,
https://www.vittoria.com/eu/tires/road-tires/road-tires-competition-race.html?tire_build=126
whispwhispwhispsmackbuttsmackbuttsmackbutt!mabbasta!;:!mabbasta!;:!mabbasta!;:
36.311
27.146
allora la prossima volta guarda meglio, le differenze tra le 3 versioni di tlr sono: il peso, la destinazione d'uso e la differente conformazione del battistrada, whisp bella cumpa
L'unica differenza, per il peso vedi nota (loro) destinazione d'uso è marketing.. il battistrada anche ;-)
Stesse carcasse, stessi materiali, stesse protezioni.. perfino stessi grafici di rendimento.
Ma va bene così.. ci siamo capiti ;-)
sheik yerbouti
i'm voodoo child
8 Dicembre 2013
18.165
9.318
disc
hai ragione, chettedevodi',
i grafici di rendimento, se per te sono uguali ti consiglio un buon oculista,
Schermata 2019-04-12 alle 13.28.21.png Schermata 2019-04-12 alle 13.28.43.png
36.311
27.146
sheik yerbouti
i'm voodoo child
8 Dicembre 2013
18.165
9.318
disc
Bene.. tu provali entrambi e poi ci dirai se noti differenza ;-)
E' già difficile notarla su coperture di diversa marca e mescola/struttura.. figurati su 2 delle stessa casa con identici componenti dove ciò che cambia è solo il disegno del battistrada ;pirlùn^
non capisco il senso del discorso, anche hutchinso fa 3 tipi di copertura con la stessa struttura/ compound lo stesso tpi , galacktic e performance con lo stesso disegno di battistrada e diversa destinazione d'uso,
da cio' che scrivi dovrei dedurre che giri coi lithion, tanto e' il resto e' tutto marketing,
sheik yerbouti
i'm voodoo child
8 Dicembre 2013
18.165
9.318
disc
Se non capisci il senso.. trovo inutile parlarne. (cmq vale anche per altri.. come appunto il caso che hai citato se non forse che in casa Hutchinson i pesi tra le differenti versioni cambiano un pò di più.. e per chi è sensibile a questi potrebbero fare la differenza)
anche qui consiglio una buona lettura delle specifiche, galacktic 240gr, performance 255gr, differenza 15gr, vittoria corsa 290gr , vittoria control 300gr, differenza 10gr, nelle pesate eseguite da 2-rbike la differenza tra le due coperture e' di 24gr corsa 285, control 309, poi sappiamo benissimo che il peso delle gomme varia da gomma a gomma,
sempre confrontando coperture da 25mm
continuo a non capire dove vuoi arrivare e cosa vuoi dimostrare,
Lupocerviero
6 Settembre 2016
...un paio!
Amici ex prof me lo sconsigliano. Mettendo coperture diverse, per cui si ipotizzano scorrevolezze diverse tra uno e l'altro, c'è il rischio che l'anteriore scorra più del posteriore o viceversa, creando forze contrarie che potrebbero spezzare i telai in carbonio...Ok mi banno da solo
Sent from my FIG-LX1 using BDC-Forum mobile app
Mio cugggino? :))):
Rone69
16 Settembre 2013
8.435
2.154
Faenza (Ra)
Non ho mai avuto pneumatici Vittoria, ricordo male o tendenzialmente i pneumatici di questa casa rispettano le misure nominali?
Sto valutando se prenderli e sono incerto se prendere un 25 o un 28 da montate su canale da 18,3, attualmente i Performance che ho arrivano a 27,7 e mi garbano assai.
sheik yerbouti
i'm voodoo child
8 Dicembre 2013
18.165
9.318
disc
Che qualcuno prima di te aveva già postato quel tipo di copertura a quel prezzo, poi se vuoi scegliere l'uno o l'altro diventa un fattore soggettivo per lo più legato al marketing, ti è più chiaro così ? ;-)
continui a non capire che sono due coperture destinate a due usi diversi, ma va bene cosi non voglio insistere, per te tutto si riconduce al marketing,
