S
sante pollastri
Guest
ciofecca gialloblù;2904825 ha scritto:Moooolto più scarni del solito Sante, my english is very very little ....
bene,e perchè ti ostini con l'italiano?
which i s the better geometry(for a bike,not for a frame),trditional or slope?
thanks.
ciofecca gialloblù;2904844 ha scritto:Darrell,
I see with pleasure that we start to use the Google translator.
I hope what I wrote tonight using the Google translator to understand the findings, or ask one of my friends in Rome, called Sante Pollastri to be my interpreter, in which case we would be riding ....
ciofecca gialloblù;2904846 ha scritto:Sante what questions do you?
"Te possino"... (this can not be translated, excuse me Darrell).
Obviously Sante joke, considering that Darrell builds a model characterized by slope.
nun c'è probblema!
stasera Antonio e Peppino ci fanno una sega(handjob...),a Ciofè,lascialo rispondere,prima che rinsavisce!:rosik:
thanks.
for Darrel:Antonio e Peppino.....
YouTube - totò peppino malafemmina, la lettera
I know of them
classic comedy
I have done two hours on my bicycle this morning
I have eaten breakfast
and drunk for my cup of tea
I must descend to the cave now
SEMPRE LAV0RO
Ciao
which is a tiny bit lighter and little more rigid.
it refers to a frame not to a bike,imo.
the sloping top tube or compact frame is tiny bit lighter and a little more rigid.
More rigid is NOT faster.
More rigid might feel better
giving the rider more confidence
but never faster
I have got to go
I will be back later
Ciao
The performance differences are small
but some times the sloping top tube is a better fit to the position of the rider.
The sloping top tube has minor structural merit
with the two smaller triangles of frame tubes
I use approx 6 degrees of slope to the top tube
This drops the seat tube approx 60mm
Shortens the top tube by 15mm
and the seat stays by approx 45mm
The seat post must be longer and have enough rigidity so to not behave like a fishing pole.
All this saves appox 40 -50 grams. That is all!
(Green bike picture, it is my current weekend bike)
One advantage of a sloping top tube is get the head tube higher for less athletic riders. (Blue Randonneur Picture)
and for very small frames (pink bike) you can have more seat post showing and top tube clearance
The horizontal (level) top tube works just fine in most designs and looks nice.
For many it is what they have always known.
That is cool.
My next bike for myself is going to be a Cadenzia frame with Dario's new carbon fork to test. This frame will have a level top tube will will be stiff for my size and weight due to the XL tube size. It will be an interesting experiment and I may also use the new XL XCr tubes for lugs for extra fun.
(refer to attached CAD drawing)
Over the last 15 years I have made myself only one new bike that I ride! (The Green one)
It will take 30 years to explain 30 years of experience
"A bicycle is not a sofa"
Dario Pegoretti
all things have to be taken into the project
It is about the intended use for the bike.
and then I design the frame geometry to fit under you for the bike's intended use.
I select the materials.
I do use fragile tubes, there is no benefit in saving 100 grams and havijng a fragile frame, there is no performance gain. I long lasting bike for your hard earned dollars is important.
We speak and I explain my rational of design and choices.
Refer to attached sample CAD drawing.
Then the metal work will begin.
