Garmin Edge 1030
marcomilano
5 Novembre 2010
4.434
1.492
Lombardia
www.marcogiardini.com
tutte Nere ed una azzurra
Se l'avessi saputo avrei aggiornato oggi direttamente dalla 6.30. Nessun problema il passaggio dalla 6.46 beta alla 7 ufficiale?
Sent from my SM-G965F using BDC-Forum mobile app
il piu' e' sapere dove si trova..... non c'e' da nessuna parte. Di solito garmin, oltre al rollout, la lascia scaricare per fare l'installazione manuale, ma ora come ora non c'e.
Ipercool
Ciociaro
13 Agosto 2012
11.959
9.536
63
Atina (Fr)
Trek (alcune)
Changes made from version 6.30 to 7.00:
  • New Beta Feature: Galileo satellites. There is now support to use the Galileo network of satellites to assist in getting GPS fixes. With the correct GPS firmware, this option can be enabled by selecting GPS+Galileo in the GPS setting. Sync the device with Garmin Express to make sure that the new line of GPS firmware is provided to the device. Without this, the option will not be available.
  • Added cycling dynamics support for 3rd party power sensors.
  • Updated smart notification categories. In the phone settings, social and other smart notification categories can be enabled. This will make the Edge show notifications from other applications depending on how they are categorized by Garmin Connect Mobile. Apps like WhatsApp, GroupMe, and Twitter may show up under social and things like e-mail, calendar, and news may show up under other. These categories are off by default and must be enabled to be seen.
  • Fixed an issue causing cadence and power data dropouts.
  • Fixed the activity profile routing mode getting reset to Road Cycling mode.
  • Added prompt to indicate when a course has more course points than are supported by the device.
  • Improved Shimano STEPS response time.
  • Fixed lens mode VIRB setting.
  • Fixed issue with transmitting front and rear gear information to the Varia Vision.
  • Fixed sharp bend notifications on the Varia Vision.
  • Fixed crash when using Varia Vision with workouts.
  • Fixed issue with elevation back correction that could allow large dips in elevation.
  • Fixed issue where the GPS data field did not match the GPS indicated by the status bar.
  • Fixed issue where virtual partner features were disabled for third party GPX TRK courses.
  • Added the current software version to the power on page.
  • Fixed issues with device transfers.
  • Completing a segment will now turn on the backlight.
  • Added a minimum scale to the altimeter page so that small elevation ranges are reflected properly.
  • Fixed elevation zooming issue with large courses/activities/segments (>100mi or km).
  • Improved activity auto-start when the device is stationary.
  • Updated radar tone to be easier to hear.
  • Minor bug fixes and stability improvements.
  • Minor CIQ improvements.
Reactions: Tapinaz
aleali
7 Aprile 2010
1.819
490
Valsassina
Bianchi Infinito CV Ultegra
Io aggiornato stamattina con express, per ora ho provato a vedere il funzionamento gps-Galileo e ho notato una differente modalità di segnalazione degli avvisi Varia radar
Reactions: Tapinaz
dexter.ale
18 Luglio 2010
301
8
Trek emonda SL8....Santacruz nomad carbon
Che migliorie porta il nuovo aggiornamento 7.0 ?
Cmq anche se dopo aver fatto hard reset e anche sul garmin 1030 fatto reset di tutto... continuo a non ricevere le chiamate sul dispositivo. La cosa strana che non capisco è perche nel rilevamento incidente,quando aggiungo i 3 numeri di telefono un numero mi viene scritto giusto e gli altri due mi vengono numeri doppi,nel senso che sotto al nome ci sono due numeri uguali di telefono ad esempio scritto cosi
Claudio
345878898
345878898
Ho provato a rimuovere i contatti dall'app sul telefono poi fatto il reset del 1030 ma nulla,continuo a vedere i numeri doppi...
aleali
7 Aprile 2010
1.819
490
Valsassina
Claudio
345878898
345878898
se non ricevi le chiamate dissocia e riassocia al telefono
Reactions: Tapinaz
Bärele
21 Settembre 2012
314
59
Bergamo...Provincia Sud..la parte piatta
Bianchi Via Nirone 7
Aggiornato al 7. Sul settaggio GPS non vedo GPS+ Galileo. Mi sfugge qualcosa?
Inviato dal mio SM-G950F utilizzando Tapatalk
Per abilitare GPS + Galileo, devi una volta installato il firmware 7 o la beta, collegare l edge al garmin express ultima versione 6.1 (mi pare) e installare l l'aggiornamento del firmware del chipset GPS ...solo dopo avrai anche il supporto a Galileo
Inviato dal mio Cellofono
Reactions: speedygabry
diego1971
11 Gennaio 2009
2.673
432
bollate
Tutte
aggiornato garmin express alla 6.11.0.0
aggiornato il 1030 alla versione 7
di galielo nelle impostazioni nemmeno l'ombra
si deve vedere nel menu del gps o no ?
Bärele
21 Settembre 2012
314
59
certo che lo devi vedere nel menu GPS... lo devi vedere come GPS + Galileo ... come vedi GPS + Glonass... però attenzione una volta installato il fw 7 e riavviato l edge ... lo connetti al Garmin Express e DEVI vedere che c è un un'aggiornamento del FW del chipset... lo installi ...ennesimo riavvio e ti ritrovi Galileo...
aleali
7 Aprile 2010
1.819
490
Valsassina
Io stamattina al secondo collegamento dopo avere aggiornato non ho trovato nessun ulteriore drive da aggiornare... quindi semplicemente ho risincronizzato e all'accensione avevo anche Galileo
Inviato dal mio SM-G935F utilizzando Tapatalk
Reactions: Tapinaz
