blade9722
- 18 Agosto 2020
- 1.524
- 536
- 53
- Bici
- Tigerstone Lightweight anni '90 modificata, GT grade Carbon 105
In realtà sta scrivendo l'acqua calda, ma la sua conclusione è superficiale.Solo per precisione, per sfatare il mito-storiella del peso "nella zona periferica".
“An ounce off the wheels is worth a pound off the frame,” goes the old saying, implying that rotating weight, especially on the wheels, is supremely important. The claim is sometimes laid out in less hyperbolic terms that weight on the wheels counts twice because when you accelerate you have to get it both spinning and moving forward.
Problem is, it’s not true. In 2001 bike engineer Kraig Willett analysed the forces on wheels(link is external) and concluded:
“When evaluating wheel performance, wheel aerodynamics are the most important, distantly followed by wheel mass. Wheel inertia effects in all cases are so small that they are arguably insignificant.”
The idea that rotating mass is important comes from the belief that wheel inertia matters, because it’s inertia that has to be overcome to accelerate a wheel. But Willett clearly demonstrates that wheel inertia doesn’t matter, so rotating weight is also relatively unimportant.
Why not? Well, you don't do much accelerating when you ride a bike, and even when you do the acceleration is relatively low, so the power expended accelerating a bike with ‘heavy’ wheels is only fractionally higher than that needed for light wheels. Overall weight matters when you’re climbing, but even that’s not as big a factor as people imagine and it’s a lot cheaper to save weight off your middle than the bike.
In fact you spend most of your time, and therefore effort, shoving the air out of the way, and that’s a far better basis for choosing wheels. The roughly tenfold difference in the effect of aerodynamics versus total mass means you’re far better off with a pair of good aero wheels than a pair of light ones.
Che la massa rotante a livello del CERCHIO (non è così per i mozzi ad esempio) conti il doppio è vero, e basta un semplice conticino di fisica uno per verificarlo. Questo impatta sull'accelerazione: risparmiare mezzo chilo sui cerchi equivale a risparmiare un chilo sul telaio. Che poi un chilo sull'economia totale abbia un impatto relativo è corretto.
In salita, a velocità costante, non è così, mezzo chilo sui cerchi pesano mezzo chilo.
In pianura, a velocità costante, il peso è irrilevante.
Poi è vero che i cerchi ad alto profilo permettono di risparmiare potenza, in pianura, a velocità costante. Ma il risparmio dipende quadraticamente dalla velocità. Per questo, potrebbe essere poco significativo a basse velocità.
Quindi, se vuoi avere un vantaggio in salita, dove le velocità sono inferiori, ed il peso è importante, vai di ruote leggere a basso profilo.
In pianura, ad alte velocità, dove il peso è irrilevante, ruote ad alto profilo.
Se fai gravel in single track, dove continuamente acceleri e deceleri, conviene leggere a basso profilo.
Poi è ovvio che conta la gamba
