Magene Pes P505
andrx
11 Luglio 2013
1.089
305
Rovereto
www.strava.com
olympia speedy plus
Comunque il magene permette tramite magene Utility di modificare la % rilevata quindi puoi uniformarla al tuo smart trainer
mi intrometto, l'altro ieri ho proprio aperto magene utility (che devo stare attento a non farlo aggiornare dato che il mio pes è la versione cinese e non lo vedrebbe più) e ho visto questa funzione.....ma comunque a cosa serve esattamente?
Coverstem
18 Agosto 2014
3.629
1.077
Asti
www.facebook.com
Based on the search results"power slope" in the context of power meters (PM) refers to slope adjustment or calibration scaling. This is a, often manual, method to change the wattage values displayed on a bike computer by altering the constant (multiplier) used to convert the raw torque data from the power meter into watts.
Power Meter City
Here is a breakdown of the information regarding power meter slopes:
  • Definition & Purpose: The slope represents the relationship between torque (force) and the electrical signal produced by the power meter. Manually adjusting the slope allows users to scale their power data (e.g., to make a power meter match a smart trainer).
  • Calibration (Slope Setting): If a power meter is consistently under-reading, increasing the slope value will increase the recorded watts; decreasing the slope will lower the reported watts. This is typically done through the power meter's proprietary app or compatible head units (e.g., Garmin, SRM PC8).
  • Procedure: A common, recommended method for testing and calibration is to perform a steady, controlled ride in Erg mode at different watt levels (e.g., 100W, 200W, 300W) to check for consistency across the power range.
  • Limitations: Not all power meters allow manual slope adjustment via user-facing apps (e.g., some users reported issues adjusting Stages or specialized SRM models).
  • Related Concepts:
    • Zero-Offset: A separate, routine calibration that simply sets the baseline reading to zero before a ride.
    • Power Scaling: Using the manufacturer's app to apply a multiplier to the final power data, often used as an alternative to adjusting the raw slope.
      Reddit +4
Commonly Used Power Meters with Manual Slope Adjustment:
  • Quarq: Allows slope input to calibrate accuracy.
  • SRM: Requires specific, direct input of the slope value.
  • Garmin/Apps: Used as the interface for adjusting these settings
EugeBal
18 Settembre 2018
1.519
2.076
63
Brisighella
Volevo montare qualche cosa di più leggero senza svenarmi però.
ho fatto questo:
pierluigi
[TrainerRoad] Team BDC
1 Agosto 2007
1.392
310
Tarmac PRO
ho fatto questo:
Grazie molto interessante ma mi servirebbe con il perno da 24mm
EugeBal
18 Settembre 2018
1.519
2.076
63
Brisighella
andrx
11 Luglio 2013
1.089
305
Rovereto
www.strava.com
olympia speedy plus
Buongiorno... info tecnica.. bici scott foil con movimento centrale press fit e guarnitura ultegra 8100 .. sostituendo la guarnitura con il pes 515, il deragliatore di2 è da regolare? Grazie
Probabile , comunque ti metti li con l'app e dalle impostazioni sposti il deragliatore cliccando su + o - e vedi come va meglio...... però può anche essere che vada bene così com'è
bridge_184
6 Novembre 2020
128
13
42
Orba Orca Aero
Buonasera.
Ho installato il powermeter Magene PES515 circa 1000-1500km fa. Da qualche uscita sento questo fastidiosissimo rumore quando spingo in salita (TIC-TIC) che sparisce quando spingo in piedi. Spero si riesca a sentire dal video e che riusciate darmi delle ipotesi. Sono andato dal meccanico ma non ha trovato nulla. Il rumore si innesca con sobbalzi o anche cambi di direzioni improvvisi. Dite che possa essere il Magene? Altre idee?
Il meccanico ha ingrassato, pulito e stretto. Inizialmente sembrava quasi sparito ma invece è tornato più fastidioso di prima
  • 607A71D3-EC3D-4AA1-9977-2F985AB537B2.MP4
    23,7 MB · Visite: 0
  • C2727064-9FF5-4269-9C17-CD65869F616D.MP4
    27,7 MB · Visite: 0
